Found five 19" TV Tubes & 1 25"...what games can they go in?
So it was fall cleanup this week, and I took advantage and grabbed any 19" TV that I could find. I took all the tubes out and wrote down the model numbers and Ohm readings. None of them match what I need for my Pacman GO7 or my Defender K4600 chassis' based off the Ohm readings, which sucks! Just curious from anyone with more experience if these will fit in any other machines that you may know of. I would hate to have to just ditch these tubes in the trash!
The 25" tube I have I am hoping will match the tube for my MK1 cab I have. If anyone can verify that for me, that would be appreciated! All I know offhand is that it is an original monitor tube and chassis from the game. If there was more than one, then let me know and I will confirm what is in there currently...would just have to do a little digging to get it out!
Here are the tube #'s and Ohm readings. Let me know what you think I should or could do with these! Thanks!
19" Tubes
A48LGS30X14A-ORION
HOR.=4.0 VERT.=13.1
A48AGY13X77-ORION
HOR.=2.6 VERT.=13.7 CR23-FATNECK
A48LG530X-THAI CRT CO.
HOR.=4.5 VERT.=13.0
A48AAB13X02-RCA
HOR.=3.7 VERT.=11.7
A48LRH93X-FUNAI
HOR.=3.2 VERT.15.0
25" TUBE
A63ADT15X09-RCA
HOR.=1.8 VERT.=3.4
Thanks in advance for any help and advice that you can give me!!
19" Tubes
A48LGS30X14A-ORION
HOR.=4.0 VERT.=13.1
A48AGY13X77-ORION
HOR.=4.5 VERT.=13.0
A48AAB13X02-RCA
HOR.=3.7 VERT.=11.7
A48LRH93X-FUNAI
HOR.=3.2 VERT.15.0
25" TUBE
A63ADT15X09-RCA
HOR.=1.8 VERT.=3.4
