Found: Demolition Man plastic subway ramp.
How bad is it broken?
My Black Rose had a small triangle piece busted out of it, luckily I found the piece when I stripped it down to shop it out. I used Gorilla Super Glue to put it all back together then also used Gorilla clear repair tape or something like that they sell really thick clear tape that holds very well. Total cost around $15 bucks I think or less. Of course if you find the piece that's better but if not this could work I had to do it also because that ramp is not available and very hard to find.
I buffed out quite a bit of the white cloud out of bit also and it has been holding up just fine for several months now
It is completely missing one of the support rings at the end of the ramp. It causes it to slip down and causes the ball to stick stop. There's also a huge chip out of the end which is also missing.
