I'm saving them for sure. There are no more arcades in Memphis except for Putt-Putt off Summer, and it's pretty weak. What should I use to clean them up?
Should be able to use the harness, after replacing all of the old connectors. Probably a good idea to do that, as a general rule - replace the crappy IDC housings with molex housings and use crimped on trifurcon pins.
As bad as the original cabinet might be, since it's plywood (delaminated) and not MDF or particle board (swelled to be larger), you should be able to use it as a template for the new cabinet. Rough cut the new panel, clamp it to the cabinet (on its side), and use a flush trim bit and go around the cabinet. Not that hard. Williams used dado joinery, you can do that or use butt joints along with biscuits for strength.
Biscuits don't really add strength to a joint. The help with aligning up the adjoining pieces.
I'm in the process of reproduction StarGate/Joust/Robotron control panels. The most difficult part is the angled dado and rabbet.
Darren Harris
Staten Island, New York.
I thought those staples in the Atari cabinets were just to hold the pieces together while the glue dries.
As for my Williams control panels. Two jigs identical jigs would be all that is needed. They would be exactly the same, except that one would have 9° slant for the lower portion of the control panel and the other will have a 10° slant for the control panel top.
They were easy to design, but in order to make them I have to determine if it is plausible to rip cut a 2" x 4" on my table saw with the blade set at an angle and the 2" x 4" on it's edge.
Darren Harris
Ok, cool. The first thing I was gonna do is buy a wiring harness to see if the boards work. I don't have any friends in the hobby so I'm all by myself.
Other than that, I wanted to get the monitor set up first to see if my galaga boards work, too, lol.
... Do you guys know how to clean some old tokens? I was thinking a soak in CLR or something similar.
Wow, that's fantastic. I'd love to check out the collection sometime. I don't believe you have all those games, lol! QUOTE]
You're welcome any time. I hope to have a get together in a few weeks. I know of two others in our area that are in the hobby. CDJump is one of them. I've met him. I can't remember the other guys online name. I have not met him. That's a least four of us.
Well, I need some time to be officially in the hobby. I don't know if owning a dead machine is acceptable, lol.
That is true for edge gluing or face gluing solid stock, where you are gluing long grain to long grain. In that case, the glue line is already stronger than the wood.
When gluing end grain, such as a butt joint, the glue on the end grain doesn't make a strong joint at all. Mortise and tenon joinery or biscuits (which are basically mortise and tenon) creates a face grain to face grain glue joint, even if the boards are end to end.
I'm going to make a few 'new' Atari cabinets for personal projects. In replicating an Atari cabinet, you'd either need staples, as originally done, or could upgrade to biscuit joints, since you can't depend on a glue joint anywhere where there will be vinyl on one of the faces. It may be overkill, but I plan to use biscuit joints instead of the staples. It will look clean, be stronger than the original cabinet design, yet other than staple crowns/holes, will look identical.
Oh and about that control panel.. More power to you.. I was looking at it, thinking about what I'd need to make one myself. It looks like a heck of a challenge, without the jigs they had in the factory back then. You need a good router table or shaper, the right bits, and a lot of patience to nail that. I'm sure you'll get it though.
the carcass will go to the burn pile at my folks' place for a witch-burning session. Will post pics of that.
LOL, that is fantastic!
At the bottom of the cab, covered in dirt, I found a few tokens from a Space-Port arcade @ 2152 Frayser Blvd here in Memphis.
Save those pics for when someone is trolling the local craigslist with a "looking for classic arcade games" post.
"Hi, I have a sweet Williams Stargate that needs a little touch up here and there, it worked last time it was played"
"I am thinking I could let it go for 500.00, I have seen them sell on eBay for triple that."
