FS Parts: FLYBACKS! Refreshments finally! In stock!. Some improvments. makvision large screens
arcadecup
Ahhhh! A sigh of relief as I have finally gotten refreshments of flybacks for sale. It has been years I hope some of you share the same excitement!
Some improvements while may seem trivial are still a nice touch.
Wire colors for some have been changed.
e.g. K7000, mrcft-252 and 216 focus wires are now white. Instead of both the g2 and focus being red. If you're ever stuck the thicker wire is sure to be the focus and the thinner g2/screen.
Pin length. Pins are ample length so you're not fighting to seat your flyback in its footprint.
Anode cap rubbers are all going to be the soft grey material that has superior dielectric breakdown / longevity.
I now have the makvision / wei-ya flybacks in for those later model large screen tri sync and vga ones. Makvision c3125 / m3129 m2929. Flyback HI-3129C (single focus), HI-3129E (dual focus) and the HI-2929D
Now carrying the Nanao / sega one. MSH1FAC13A Sega MC-2030-S / Kaga / Nanao KB240331B new replacement flyback
A bunch of the common ones or others that I have not had in stock for literally years are are refreshed.
There are certain flybacks I may never stock again because they may be known as stable where I have no confirmed counts of a bad one or they rarely ever go bad.
I am starting to sort the flybacks into monitor board maker sub categories. some are unsorted yet.
These are on my website ready for self checkout under the flybacks tab.
Thanks everyone for the support and continued trust in me for your monitor board repairs, reconditioning and analysis.
Are these made by Hoveyking or somebody else? I haven't seen K7ks with a white wire up to mid-'16 date codes as of yet. HK's flybacks seem to be improving in quality incrementally. It's nice they went to a better quality anode cup material a few years ago - I've had to swap some out from ~10 years ago from the anode cups becoming stiff and cracking.
Only about 3 years ago I'd usually have to straighten pins to get them to drop into chassis, and now they always drop right in. My only complaint is that they're clearly putting the flybacks into the styrofoam (shipping pin-protector) while solder is still hot, so it's necessary to scrape the pins before installing for the best solder joint. They might have started to cheap out a little bit more on the pot blocks, though. The test seems to be to press on the G2 pot; the newer ones often get "jumpy".
This is good news.
I dread the day when people like you start to retire and parts like these
start becoming scarce !
JD
Will the Sega one work for the mc2000 chassis? Got a dead chassis that needs one.
The mc-2000 marked sega tube should have a monitor board using flyback MSH1FAC02.
What does your original say on the cylindrical part of your flyback?
The mc-2030s are known to be stocked with MSH1FAC13 as the one I have. As for them crossing over I don't know yet. They may be in tolerance with each other.
Makavision flys for the 3129 tri sync?
Holy shit. I was just talking to a buddy i have one of these in the garage on the shelf.
Ill get the info on it sunday and send a email.
I want a backup for sure.
My chassis is a kb240331b from a Sega Turbo w/ 19" monitor. The flyback is msh1fac02, so seems like it should work!
Edit: oops nevermind, just re-read. Not the same number.
Very old post but hoping you may still have or know where I can get an hl-2929d flyback for my Makivision / wei ya board
