flyback for wg25k7101
that's a K7000 series chassis. meaning any K7000 flyback will work for it. as common and popular of a monitor as that is, I'm surprised those places don't carry flybacks, unless you were looking for a K7101 :)
www.therealbobroberts.net is a favorite place to buy shit on this site.
if ou want to post a pic of the chassis and fly feel free to so we can verify, im pretty sure that is considered a standard k7000.
I got rebuild kits from bob roberts, flyback, caps and a HOT. What is there to know about a hot, and what other things in a k700 should be looked at for blown fuse. I read something about transistors maybe>
the 4 diodes in the power supply section will smoke the fuse as well if they are shorted. and the 2 in the degauss circuit.
check D13-D24
C36-C38
C55 also its the filter cap
all that will smoke a fuse as well as a blown H.O.T and fly.
Peace
Buffett
definately a stanrard k7000 chassis.
053X0528-001 is listed on chads website as a replacement for the k7000 fly, *not oe* supposedly fatter but will fit and internally the same fwiw.
bob rob shows this
which may or may not be all you need. if you dont cut power immeadiately or its blowing fuses after a fly failure likt that, youll need a hot, probhably a regulator, mabye c36, mabye some diodes etc it just depends on how lucky you get and now it failed electrically.
