Doe anyone know if it's possible to make the serial port persistent to ttyUSB0 ? (and also for the tape file?)
(I now have to enter it each time after a reboot)
External trigger function is implemented in the probe add-on board. At the Moment, we use a footprint for a rectangular BNC connector (as was used in the original). This adds a signicant amount of height to the board stack..
I was unable to get accurate signal readings on my oscilloscope on the address and data busses without an external trigger from the FlukeEmu. @Arcadenut helped my get a BNC added to allow that connection - without the need for the probe board. This is hugely helpful and very trivial to add. See the pics he provided, just pull the signal from the existing header pins. His case is even designed with a mounting slot.
Sharing in case anyone is unaware of this useful feature!
Tauchen Sie ein in das Vintage Computer Festival Solothurn – mit Retro-Ausstellungen, Spielen und Vorträgen. Ein unvergessliches Event voller Nostalgie und Inspiration!
