bstnguy
Anyone have any experience with using a Fluke 9010a to fix an Omega Race PCB?
I have one with repaired minimal corrosion damage (two ICs, one socket, few diodes and resistors, ohmed out all traces) and it's giving me some funny readings on the Bus Test.
The manual isn't much help, so figured I'd toss this up to the group. Error messages I'm getting is:
Active Force @FFFFFFFF - Loop?
Active Force @FFFFFBFF - Loop?
Active Force @400000 - Loop?
Active Force @100000 - Loop?
Active Force @FFEFFFFF - Loop?
And so on until Bus Test Fail.
I'm leaning towards a thermal issue because these errors don't repeat. And if I turn the board off and redo the test, the errors again don't repeat.
Short RAM Test will pass some high and NOVRAM, but will then start failing on repeat.
I'm able to write to high memory, read high memory, then after a couple of minutes, I can read, fail write, re-read failed write which is correct and then fail read, and everything fails. Again, power down, power up does not repeat the failure.
Same on the NOVRAM.
Suggestions? Comments?
Same on the NOVRAM.
