Florescent light help -TRON
Happyday
California
I have 3 lights not working on my Tron:
- The backdrop light- light does not come on.
- The black light above the joystick only lights up at the ends.
- Light above coin door does not come on.
The marquee light works fine. I replaced all the starters (F2) and bulbs but still not working.
Any advice???
First take the marquee bulb that works and pop it in all those other fixtures. If it does not light up then check for 120v in the molex connectors for those fixtures and if you get no voltage check the fuses on by the transformer with a multi-meter. Sometimes fuses look good and in fact are blown. If the fuses are good then the bulb sockets are bad.
This one might just need a new starter. $3 at Lowes
Agreed. The starters twist counter-clockwise and pop right out.
Edit: I just read the original post again, and you already tried this. Sorry!
