Floppy Outrun Shifter
gameonnow
Chicago, Illinois
The shifter works fine, it's just it won't hold itself in Low gear. One assumes that these parts have broken / fallen out? KR-1320 Compression Spring, 101-5004 Ball Bearing x 2?
Anyone have a photo of what the shifter looks like inside?
well...
Do they make a lil blue chip for the floppy shifter?
LOL..
I had too!!
if the ball bearing fell out, there is a good chance there is a problem with the shifter. Like its metal frame is cracked and let the bearing fall out. Maybe a grove is worn into the metal and the ball will not stay in place.. So look at that before you buy parts.
