Flipper Rubbers
FrizzleFried
NAMPA, Idaho
I have something strange going on... I replaced the flippers in Xenon with some nice new translucent blue ones but for the life of me I can't keep the freakin flipper Rubbers on! They side upward and eventually snap off slinging itself across the playfield. Three times in about 30 games or so this has happened...
What can I do to keep the rubbers from sliding off the top? Can I use some sort of liquid to create friction or something?
If someone doesn't quote hack this people are really slipping.
I would probably try some thin double stick tape. You could also try roughing up the bat right where the rubbers curve on either end. That's where they're going to come off.
A little spray adhesive will do the trick.
Glennon
Thanks for the idea.
Glennon
I have something strange going on... I like to have sex but for the life of me I can't keep the freakin Rubber on! They side upward and eventually snap off slinging across the bed Three times in about 30 tries or so this has happened...
What can I do to keep the rubbers from sliding off the top? Can I use some sort of penis pump?
Fixed it for ya.
Well,
I started by scuffing up the bats at the ends with sandpaper. We'll see if that does the trick. If not, I'll try something else.
Well,
It's nice to see you spending some more time over here in the pin section.
Glennon
