Flipper coil gets no power. Where to test?
ReWrite
California
My lower right flipper coil on my Judge Dredd isn't receiving power.
I found on pinwiki that the coils should be getting 20-60v when tested, and the other 3 are, but not this one.
I've tested for continuity along the wires, and there are no breaks or anything.
No idea what direction I should be going in right now.
You have continuity of each wire to the fliptronics board ?
Did you pull and check fuses on the fliptronics board ?
Then I'd measure power leaving the fliptronics board, in case you have other problems on it.
LTG :)
Yes!
Uhhhh... Nope. Just did, and one of the fuses has blown. I'll have to pick some up tomorrow!
The power that goes out through those wires? Am I measuring the pins on that connector that goes to the flipper coils, or?
And by the by, you seem to help me a lot, so really, thank you.
The fuse will probably fix things unless it pops again. ( then I'd suspect bad coil or bad diode on it )
When I suggested power leaving the fliptronics board, I meant at the connector going to the coils.
LTG :)
