Kryzsky
About to install a flipper rebuild kit on my T2, I wanted to double check with you guys before going ahead. I've read quite a bit online but got confused when I went over to a friend's and saw different connections on his T2 flipper coils and EOS. This is my first rebuild and want to be sure so I don't melt anything down.
With these connections, current flows through the larger coil wire when the button is pressed since the switch is closed. Once the EOS switch is opened, the large coil wire is taken out of play and current now flows through the small coil wire to hold the flipper up.
Did I get that right?
Also, am I correct in saying the wires that deliver 70 volts can be connected either way? Since they do not have a ground reference?
Thank you
Thank you
