gabesdad1981
Guys I just picked up a flat panel 20 in mon with one of the VGA converter bds... should this be an easy swap into my tapper, i can make it fit easily get ac to the mon, get the 12 volts to the converter/inverter( whatever its called) then i have the rgb and syncs hooked up ,, then no matter which connector i connect the vga in or out on the inverter bd i get no signal to monitor
( ill include a pics , keep in mind this is all just in the floor trying to get it to work before I make more permanent including the power supply for the 12 volt supply)
