Flat or curved crt not interchangeable?
Florida
I have at flat kortek 2914DF tube that I hooked up to a chassis I pulled from a curved kortek 2914DF that had a broken tube. Both used the same chassis..
but the picture is curved when I hook the chassis from the curved crt to the flat crt.
No amount of on screen adjustment will correct it. Is there a jumper or yoke setting I can change or are these two chassis just fundamentally different?
Chris
the manual shows different part numbers for the different tubes and the parts between them that are different.
