Flashing light adjsutments
Fatality83
manchester, Pennsylvania
On my Rowe Eagle Laserstar there is a knob in which you can adjust the sensitivity of the blinking lights to the music. There is also 4 dip switches. Changing them gives you the option to have the blinking lights blink all the time, stay lit solid all the time or stay lit in standby mode and blink when music is on. I want them to stay lit all the time and blink in standby mode so I set the switches to the correct setting. However the lights still blink in standby mode. They are supposed to stay lit solid. Any ideas what may cause this?
Sometimes the dip switch assembly goes bad internally due to tarnished contacts. You might have to replace the dip switch with a new one.
