When I turn the machine on, the volume is cranked until I go into the settings menu and reduce it. As long as I do not power off, the volume stays where i set it. Every time I power it off and back on, it's full volume again.
I presume my first step should be to check/change the battery for keep-alive memory. Will do that in the next few days, but is there anything out there that is a common problem causing this that I should check while i am in there?
Thanks, mongoosetoo
Thanks, mongoosetoo
