parabolic
I have a Mr&Mrs Pac pin. I have recently broken a drop target, and kinda need it up and running sooner than I can order a new one. Is there any fix I can do that will last a bit? I tried using a 5 minute epoxy, but it still didnt last. It worked for a while, but then it broke again in the same spot.
I was wondering if any of you had fixed these sucessfully, and what kind of glue was used? Apparently this was broken before and"fixed", but again that wasnt probably the best fix as well.
Its snapped at the hole that the return spring hooks into - yah the weakest area.
Thanks!!
Thanks!!
