Fixed my 150 in neo geo multi cart..
mrbill2084
san jose, California
I have had this one for a long time. When I plugged it in, it worked like it had a dirty slot.. I tried a second 1 slot pcb and same thing.
So I took apart the cart. It has an expansion pcb that sits between the 2 cards that was not sitting in correctly(kind of like mini sega system 18 setup). I reseated it, put it back together and the cart works fine..
simple fix, but since it makes it look like a bad pcb cart slot, you might waste time thinking its a pcb problem..
thanks for posting this. I have a 120 in 1 that has decided it wants to reset once in a while. I will take it apart to check.
thanks,
Paul
