Evening folks. My Donkey Kong 3 PCB is missing all sprites. I found a post on MikesArcade that indicated this could be a bad Z80-DMA. Ordered a couple of those and no change. Changed out the socket also and still no change. Any ideas what else could cause all sprites to be gone? Game plays as it should minus sprites. Stock and with a Braze HSS kit, same result.
Also, this is in my DK Jr cab using Mike's adapter to turn the little connectors into an edge connector that works fine otherwise.
Thanks for any insight on where to look next.
