KenLayton
In Memoriam
Tekbilt models 30820 and 30920.
Problem:
Both the models 30820 (12 amp) and the 30920 (15 amp) have a couple of resistors that go bad causing intermittent operation.
Cure:
Check/replace resistors R4 and R8. They are both 270k @ 1/2 watt in value. If one is found bad, replace them both anyway.
Of course many of the Tekbilt power supplies are approaching 20 years old so it would also be a good idea to recap them too.
Tekbilt power supplies are actually made by Mean Well (www.meanwell.com) and they match closely to Mean Well models MWP-602 and MWP-606. Only difference is case color. Tekbilt has a chrome case while the Mean Well supplies are painted gray or flat black.
Problem:
Cure:
