Fix my bally strikes and spares and i will hook u up with free stuff
kjoel
bayshore, New York
Bally strikes and spares pin.. Issue it works in demo mode. Once u credit then start gameplay it does nothing, no playfield lights. When u press the flippers the balls do nothing. Seems like a power issue. All fuses are checking ok. Flippers test ok in test mode. is this a bridge rectifier issue. Slam switches test ok. Fix this for me and i will give u any of the following for free for your time. Parts, marquees, manuals control panels, monitors, boards, whatever we agree upon.
Call me if u are serious
Keith 631-645-5262
Pins are not my style but location likes them. I repair arcades all the time but still learning to repair pins.
Check for burnt pins on the transformer board. New board cost around $60 with new connectors and pins.You might want to check for battery acid damage also.
O/k kieth I got over there today and checked the game,Iam not familiar with gottlieb like Iam with B/W, but none of the Coils are working in test mode,also with not scroll through the menu with the flipper button,any gottlieb DMD guys on here that can help send me in the right direction and save me some time going over schematics.I did check all the fuses out of the game with a rather expensive multimeter and all checked ok
I wish I knew thing #1 about Gottlieb systems (this is the Gottlieb "Strikes 'N Spares" just to clear up that confusion).
But I'm the same way. I know Williams systems pretty well, not so much with Gottlieb/Premier.
-Hans
-Hans
Well Iam already getting close,apparently gottlieb shared lines for the switches and the coils,it seems this issue is going to be related to the driver board.I could still use some advice,but it seems it's not going to b easy.
-Hans
If it was a Bally strikes and spares it would be fixed already.
Great to hear progress is made. I will do some research regarding the driver board. Keep up the good work.
