Fish tales flipper died..
Where do I begin? One of the flippers is completely dead! Thanks for any info!
1. Does the flipper button register in switch test?
2. Check the fuses on the Fliptronics flipper control board in the backbox. It's the one in the far upper left. Pull the fuses and check with a meter on continuity
3. Does everything else still work?
RussMyers
Make sure the wires didnt come off the solenoid lugs. I pulled off a wire on a trough switch on my Shuttle just lifting the pf once. Got snagged on something and was fragile enough that I didnt feel it pop loose. Thankfully found it quickly.
Yeah, that's another common possibility.
It was so basic I didn't think to mention it, but yeah, check the wires going to the flipper coil lugs.
RussM
RussM
thanks guys!
I finally looked at it today. The fuse was blown and when I fired it up, everything went back to factory settings/restore...Strange.
I plugged those LED strips into the service plug...Could that have done something?
