Riptor hooked me up with a pacman power supply that he used to use to test his pac boards.
I also have a new 13 inch monitor and I need a little help getting my rig/monitor up and running.
Here are some shots of some of the stuff.
http://mrcade.com/test_rig/
Riptor does not have an iso on the pac p/s and the wires are a little hacked up but he said it works.
I have noticed that the plug for the monitor looks backwards for this little monitor. So I just want to check first before I try to power this on and toast something.
My goal is to take that power supply and put it in a small box. Then I have another project box to put a joy stick in with p1, p2 and coin slot action.
So for today the monitor will only be used for a pac or mspac setup. I will need to do the same for williams down the line. So any mods I need to do for the monitor need to be thought of ahead of time.
Can any of you guys help me out with the wiring today?
