First pin - Secret Service
mochaman
I picked up a Secret Service pin. It didn't work but know what happened. Person tried to fix a flipper and used a live wire to see if flipper would work. Short story, SMOKE! Once home, I could look for what smoked. It came from main pcb. My question is, can this be fixed? It looks like burnt traces. I have enclosed pictures of area. Hope I enclosed enough info. Thanks, Mark
EDIT: When home, plugged it in and lights came on, a hum from speaker and nothing on display. Coil fuse was replaced and blew immediately.
i believe the clear box is the flipper relay thats what most likely smoked.you have to replace it.as for cooked or broken traces you have to run a wire on the back side of board.from point to point to make a new like trace hope i helped
I removed the case on the relay and found no burnt markings. I think I need to send this out to someone to test/diagnose. Anyone have any recomondations?
