Segagee
First cap kit failure on Sanyo 20EZ, getting centered white vertical line
As the title states, I finally got done capping the 20EZ in my DK Jr to cure some vertical foldover and was greeted with disappointment. The monitor now displays nothing but a bright centered vertical white line. Game will not coin up or play blind either. Checked my cables on monitor/game board, vertical size, service switch on monitor chassis, solder joints, and everything seemed to be OK including C407 and C408.
I did mess up my first C408's polarity while soldering, but caught this error and replaced it before re-installing the monitor chassis. This location proved to be a bitch as it took me numerous times to produce a healthy solder joint here; even so I do not think I burnt a pad or trace at C408's' location.
Not really sure where to go next, thanks in advance for any help/advice.
