modessitt
So, I basically got everything on this damn Firepower working - except for the sound. Sometimes it works. Sometimes it doesn't. Sometimes it will go out in the middle of a game and not come back on. Cycling power doesn't help. Nothing in sound test will work when the sound is out. Pushing the button on the sound board will not make it work when it is out.
I have power to the sound board. I have done continuity checks from the board to the speaker to eliminate wiring or connectors. I have done the same for the volume control - which works fine when the sound is working.
I'm beginning to think it's a heat issue of some kind, but I'm trying to figure out if it's on the sound board or on the CPU/Driver board. I'm about to dig up another soundboard to try in it.
Unless someone has a better idea...
