Fire Escape Lamps?
jetusenet
Donor 4 years: 2011, 2013-2014, 2024
Staten Island, New York
Hi,
Finally got my Fire Escape (!) and are in the process of getting it working correctly.
One item is the lamps, for the HS, Balls, Bonus etc.... They appear to be sealed and upon opening, they look to be disposable, as in they are not meant to be re-lamped.
I am looking for a supplier of these and have not been able to locate one. Would anyone have any information on these, as in, where they could be sourced?
Worse case, I'll retrofit them with LEDs but would like to keep the game original if possible.
Thanks in advance
Jeff
Thanks for the suggestion......
The issue is that these do not appear to be "serviceable" as I need to bend the lens frame a bit to remove it and it will not make another repair without breaking.
I have decided to retrofit these with wedge bases (removable) so in the event that my replacement LED lamps ever go out (unlikely), it will be a quick swap without having to stress the metal frame anymore....
I'll post the work once completed.
Hi,
Thanks in advance
Jeff
I've got 2 banks of these on my Fire Escape that require replacement so please post a solution if you arrive at one.....thanks.
