Finally!
8up
Ohio
Well i finally got my first game! It's a sit down Power drift. It works for a few minutes then shuts off. The game was very, very dirty so i cleaned everything and put it back together. I cleaned the boards and cleaned each connector one at a time so i wouldn't mess anything up. Now when i power it up it makes a humming noise through the speakers and nothing comes on. All the red led lights come on when i power it up also. I'm real new at this and i really need help trying to figure this out. Could anyone please help me? I would really be greatfull. I will put up some pics tonight.
Sounds like a power supply issue. Have you checked all the fuses? I would recheck all the connections too.
Can i check the connections while the power is on? I will check the fuses too.
You can check the volts when the power is on, with your multimeter...dont just start pulling fuses, or connecting wires when the game is on.
Turn the game off and check all your connections, make sure none of them are burnt. After you check that turn your games on, and see if your getting the correct volts from the PS....
