KevinMullins
Ok, so the pinout I described was correct then.
1. Input
2. Base
3. Common (ground)
4. Ouput
(the STR30123 is different)
The output on that VR should be about 123VDC, hence the part number.
The input voltage I'm not positive on, I don't have a 19" chassis to verify with.
Check that the insulator for the H.O.T. is good and that the HOT is not shorting to ground. (i.e. not touching the heatsink)
You could pull one leg of D10 to prevent shutdown, but your B+ is just too high anyways to begin with.
1. Input
2. Base
3. Common (ground)
4. Ouput
