The plywood on this cab is not so nice (it was under veneer). It's much smoother, but after hours of sanding you can still feel/see the grain. I started with 80 grit sandpaper. I'm concerned that I'd be removing too much wood if I keep going, since I've already basically removed a full layer of thin wood when the veneer came off.
My goal is to be able to paint it, so I suppose I'm going to have to coat it somehow. What do you guys do in this situation? Is joint compound a bad idea? Sanding sealer? Many of coats of primer?
I'd love to hear how you'd tackle it. Thanks for reading.
