Female quick disconnects?
Atari The Jedi
Donor 3 years: 2015, 2021, 2024
Sparks, Nevada
Where is the best place online to get some female quick disconnects? I like to get some insulated .187 reds.
I look on Amazon and it looks like there's a billion people selling them but I want to make sure I'm getting good ones. Thanks :)
If you're looking for a quick female disconnect try posting this question on a dating forum.
Ayo, I'll be here all week folks.
Well shit, I was about to chime in with "Want to hear about my arcade collection?". That's usually guaranteed a quick female disconnect.
Too slow...too slow.
You mean like these? https://www.amazon.com/22-18-Gauge-Female-Disconnect-100pcs/dp/B001HTB13S
If you want "good ones" get a version that crimps using an open barrel crimper. The automotive style in the above link suck imo.
Example: http://www.te.com/usa-en/product-42452-2.html
Use shrink tubing if you need to insulate the barrel. I think TE also sells clear sleeves that insulate the spade also.
You can probably get a bag of 100 generic equivalent off eBay/AliExpress for $6 shipped. Unless you have a really specific application, I wouldn't worry about it.
I'd suggest Wiring Depot.
I do work there, so take that for what its worth. However, we do source quality components, often from US manufacturers. I'd consider heat shrink ones if you want to ensure the best possible connection and seal.
http://www.wiringdepot.com/store/c/179-Disconnect-Terminals.aspx
Give me a moment and I'll make a KLOV discount code.
Edit: use KLOV15OFF at checkout for 15% off.
I was thinking more along the lines of "the pull out method", might make a mess, but limits unplanned children ;)
