Feddy problems..Please help (left ballgate, hand and flashers(67))
jamesh007
Kentucky
I recently cleaned the playfeild on Freddy, replaced drop targets and removed claw for repair. Now the top left ballgate and Freddys hand are not working, also the Flashers (67) are not working (although flashers were not working before as I think all bulbs were burnt).. I know enough to get myself into trouble, but obviously not enough to get myself out of it Smiley I checked the fuses under the playfield and tried the solenoids on the self test and they do not work. Can anyone give me any suggestions where to start helping me diagnose; have a feeling its something simple, at least I hope. Thank you in advance !!
Did you reconnect everything you un-connected? Sounds you either missed something or mis-plugged something. Good-luck, and welcome to the world of pinballs!!
I just checked the connections and do not see any that are not plugged, took backglass off too. I did not disconnect anything when I cleaned it, and checked all around the areas I worked to make sure I did not hit or break any connections. Can any body familiar with the machine suggest any specific areas to check ?
