jouststar Active member VAPS Joined Jun 18, 2003 Messages 664 Reaction score 82 Location Benton, Arkansas Feb 6, 2018 #1 Replaced the pot because it would not steer without going erratic almost like it needed to be calibrated. That did not fix the problem. Anyone have any ideas? Attachments IMG_8210.jpg 354.5 KB · Views: 14
Encom Well-known member VAPS Joined Mar 30, 2008 Messages 1,231 Reaction score 131 Location Etters, Pennsylvania Feb 6, 2018 #2 Have you tried reloading the software? Can you move the PC to a different unit and see if the problem stays with the cabinet or follows the PC?
KenLayton In Memoriam Joined Dec 14, 2003 Messages 20,220 Reaction score 712 Location Olympia, Washington Feb 6, 2018 #3 Worn steering belt (teeth worn)? Loose screws on the steering gear? Worn/dirty motor brushes?
OP OP jouststar Active member VAPS Joined Jun 18, 2003 Messages 664 Reaction score 82 Location Benton, Arkansas Feb 6, 2018 #4 Encom said: Have you tried reloading the software? Can you move the PC to a different unit and see if the problem stays with the cabinet or follows the PC? Click to expand... Don't have another cabinet try it out with.
OP OP jouststar Active member VAPS Joined Jun 18, 2003 Messages 664 Reaction score 82 Location Benton, Arkansas Feb 6, 2018 #5 KenLayton said: Worn steering belt (teeth worn)? Loose screws on the steering gear? Worn/dirty motor brushes? Click to expand... I will check those tonight, thanks for suggestion.
OP OP jouststar Active member VAPS Joined Jun 18, 2003 Messages 664 Reaction score 82 Location Benton, Arkansas Feb 11, 2018 #6 jouststar said: I will check those tonight, thanks for suggestion. Click to expand... Belt is fine no wear. Any other suggestions?
