FA - restored Roadblasters gas pedal
mnrocketry
Donor 14 years: 2011-2024
Savage, Minnesota
Decided to sell my spare restored Roadblasters gas pedal on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260556932455&ssPageName=STRK:MESELX:IT
Auction ends next Saturday night, the 27th. Thanks for looking!
* Pedal was completely disassembled. All metal parts were cleaned and bead-blasted to remove the old coatings and any corrosion.
* The housing and pedal were professionally powder-coated "pac black" for a smooth, durable finish.
* The interior brackets were primed with "Rustoleum" primer.
* New anti-skid material was applied to the pedal.
* The pivot and stop shafts were cleaned and buffed.
* New "Nyliner" bushings were installed on the pivot shaft.
* New latex rubber tubing was installed on the stop shafts.
* The original potentiometer was tested and reinstalled with the original linkages and new wiring.
* New springs (same size, stiffness and strength as the originals) were installed.
* Assembled with all new screws and fasteners including the correct style clips for the shafts.
* It was temporarily connected to a Roadblasters game and tested to verify correct operation. Other than that testing, it has not been used.
* The result is a pedal assembly that's in like-new condition, if not better than new!
