extra cooling fan on pole position upright
kerri369
brentwood, New York
got the pole position up cleaned and running tight! here's the question(s).should i install an extra fan, where and in what direction, and if so could i tap into the existing fan wiring and run it off that? thaaaank yoou!
id install a big one in the bottom to suck air in and a big one up top to suck air out and you should be able to tap into the same wires
Pole Position Fan
I have one that an operator modded. They cut a hole right behind the board cage to blow air by the CPU and video boards.
Mark
