Exidy Side Trak schematics
Tornadoboy
North Attleboro, Massachusetts
Does anyone have a better copy of the schematics for Exidy's Side Trak? The only copy I've been able to find is in pretty crappy shape. In particular I want to be able to figure out the pinout as I want to try to make a JAMMA adapter.
Side Trak is Exidy V2 hardware - like Venture/PepperII etc.
So, you'll end up with a Jamma adapter "similar" to this -> (take note of the extra wiring and SYNC circuit)
The logic board looks the same? But not the AUD/VID daughter. Fascinating.
Needless, a good guess is that the two edge connectors have the same pinout as standard V2.
Where's the VIDEO header? Oh, ST is B/W, correct? So VID OUT is on the edge connector. Ahhh.
Shockingly, analog sound boards are different for different games.
It's got the same DIP14 connector as all the other games, so you can add a color converter board.... or include the color conversion circuitry in the JAMMA adapter like I did.
I have a copy of the schematics but don't have access to a big scanner on a friday night. I'll get a proper scan next week. DMing you pictures of the schematics.
