You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
This thread will document my scratch build of an Exidy Chiller in the smaller Cheyenne-sized cabinet. I've mostly seen Chiller in the larger Crossbow cabinet, but I'm assuming the smaller Cheyenne cabinets were also used.
I like that cabinet a little bit better as it's not so tall and unwieldy, so I'm gonna use it. I'm using my Cheyenne as a template. So far I've got one side panel cut, and I started working on the speaker panel and the front Panel that sits in front of the control panel.
This cabinet will be built out of melamine coated particleboard and 3/4" plywood. I've already got the particleboard and plywood purchased. Currently working with Rich at this old game for the artwork package and I should be able to make most of the metal brackets myself. I will be running one of Toledo flyers multi-Exidy FPGA boards in this build.
