p1899m
exidy cab. venture style . need a couple measurments
I'm scratch building a venture style exidy cab and contemplating doing something slightly different to it with regards to how the monitor and bezel mount. I need a couple measurements to see if this idea is workable or not.
I need these measurements from an exidy cab where the bezel and monitor are mounted as they do in a venture cab. I know pepper II's were also found with this monitor orientation sometimes.
I need to know a measurement of the bezel plexi from top to bottom. The actual size of the plexi not just what is visible when it's mounted on the game.
I also need a few measurements for the piece of the cab that mounts between the speaker area and the top of the bezel. Need to know the length top to bottom.
I also need a measurement from the top corner where that panel mentioned above meets the speaker area out to the front of the marquee. Basically I need to know how deep the panel sits back from the front of the marquee.
I also need a measurement of depth from the front of the cp to the back panel. Basically where the wood meets the bezel. I need this depth as it should give me the angle that this panel sits in the cab.
If anyone can help it would be greatly appreciated.
Thanks, Dan
Thanks, Dan
