Exidy Cab ID experts...
modessitt
Austin, Texas
We have a converted cab in storage with an Exidy tag on the back, but nothing listed for model #. It looks like the cabs seen below, but the left door is one big solid door with an Exidy imprint in the center, rather than an over/under like is seen. Otherwise, the control panel sides and cab shape are as pictured. Were there versions with one solid PCB door, or is it a different cab?
What do you mean by "solid"? My Mouse Trap has the over/under doors, but they're welded together with a small plate on the front, so they open as a unit, and there is a single opening behind the door (the boardset rolls out through this door since there isn't a normal back door).
my mouse trap is just like the one you describe Mod. Not like the one in the flyer. I believe they were probably just different runs or whatever. You have a mouse trap.
Just as mentioned above, this is one big solid door - not welded in the middle. It has an Exidy imprint in the center that you can feel on the back side....
