bfuehring
Ever seen this? Galaxian Hardware running centipede?
Some friends recently bought some boards and I was browsing through them to check titles. Found two Galaxian boards and I chuckled out loud when one of them had a sticker labeled "cenapeed". We decided to test several of the boards and when we plugged in the "cenapeed" it ALMOST worked, and it is definitely playing centipede. Definitely started life as a Galaxian, and still has the satellite board with ROMS, and the two lower Proms. We can't find any hacks or cut traces. You can see the centipede, the shooter (which happens to be a fly) and the wierd bettle thing instead of a spider. The colors are quite a bit different, and the characters are noticably changed. Another friend is taking a crack at repairing the pcb, since there are H's all over the open areas, but I just wondered if anyone has seen this hack? Long ago, I found a galaxian board that played pac man, and it was interesting. Didn't have the same sound, graphic qualities, but sure did play.
Anyway, share your thoughts!
