ever see this problem with a sharp tv?
mrbill2084
san jose, California
tv is probably 8 years old now. Its sharp 32 gp-1u. About 6 months ago it started doing this. If its been off for say 8 hours, the right side spins like slot machine reel. But after about 2 min, it locks in fine.
any ideas? Should I wait for it to fail before I open it up and try to fix it?
thats probably D/A converter board. Its usually the board that everything connects to (not the power supply). I wouldnt think a TCON board would do that.
I would open it up, and with it on press lightly on the ribbon cable connections. It looks like the ribbon cable to the right side of your screen is either loose or starting to crack at the LCD. I've seen this happen before at the main board, t-con, and LCD.
