mecha
I re-capped a 33K8000 earlier and had several caps that were of higher voltage values in the chassis than what were in Bob's kit. while there's a likelihood that this chassis was re-capped by someone else previously and that their replacement caps were simply of higher voltage values than what were in it originally, I didn't want to risk it.
the reason why I even capped this was because the horizontal position will not move the screen to the right. it's not quite at foldover state on the left side, but it's definitely outside the viewable area.
in the corner of the deflection board next to the width coil there is a horizontal size pot (it's not on the remote board) and next to that is a cap that wasn't included in the kit. it's a large 10uf 50V cap (there were 3 other caps of the same value but were the tiny kind, what's the difference?). would that have anything to do with the horizontal position problem I have?
I understand these are a rare breed and very difficult to tangle with cause of their obscure nature, but I'm sure someone not named Chad Entriger has mucked with them before.
