est lights on em bally
armyaviation
Enterprise, Alabama
test lights on em bally
is there a way to illuminate all the lights at once on the em bally games. i have a 76 freedom. i cant get the lights under the playfield, not on the playfield but in the cabinet, to light up. plus it would make it easier to check for burnt out lights
maybe using a computer power supply? use a jumper wire from the ground to ground and 5v to the positive for the lights? not really sure, should be able to see what ones are working and arent
Most times when going through a machine you just replace all the lights so your not lifting the playfield every time you play it to fix a light. As far as turning them on you can lift the playfield and start a game and manualy activate relays to light the lights, but be very careful to not get shocked.
Glennon
