Escape from the Planet of the Robot Monsters - restoration help
spoonelli
Donor 6 years: 2016, 2019-2021, 2023-2024
Pennsylvania
Snagged a dedicated Escape machine at a local auction - didn't have a read on working status so picked it up on a flyer thinking it might become a mame cabinet. turns out it's in pretty good shape, so now i'm in restoration mode. this is my first go at this, and I had a couple of questions I was hoping you guys could help me out with (that i couldn't easily find solved elsewhere in the forums)
Bottom cabinet speaker - top speaker is fine, bottom speaker cabinet foam completely disintegrated. Model is B20EU90-51F - 8ohm. looks like a.pio 8" speaker. Can't seem to find an equivalent model that might work - would like to buy new given it's typically short money. Any ideas of something that would fit the bill here?
Hall Effect Joysticks - I now am discovering these are pretty tough to come by since they were only used on a few machines - anyone have experience with these? I did a full disassembly of both sticks (they were "crunchy" to say the least and wouldn't return to center), and after a few hrs of intense cleaning plus some fresh lithium grease, I'd say they are in acceptable working condition with some spring back to center. I'd love to find replacement springs for the internals, but it's not a deal breaker. Pulled it into the test mode, and one of the Hall effect sticks seems to be varying in the read at dead center - not a ton, but definitely enough to register outside of the dead zone...ay idea if this a cleaning issue with the sensor itself, a magnet issue, or something else? Also, can/should I try to clean anything on the Hall effect sensor? Other than a little compressed air, I was hesitant to touch it.
Power cord protector plate - looks like the back of the machine would have had some sort of grate/fitting in the hole where the cord comes out. I've tried to search for some sort of similar part but coming up short. Any ideas?
Thanks so much!
Hello I just picked up a dedicated machine a little while ago also. What a great game.
I order a rebuild kit for my joysticks also the plungers where really worn out, mines would not return to center and they where sloppy but this fixed them. It was from eBay but I believe it's a klov member that sells them look for Hailrazer's post on his Gauntlet restore.
How is the Side art on yours, there doesn't seem to be any for sale and some good scans would help if you have good side art. I have scratches through my side art.
Thanks! I'll check that post out.
Side art is actually in pretty good shape. a few scratches but nothing crazy. I'll send some photos and you can let me know if helpful.
