Escape from planet of robot monsters sound missing
dyno
Lower Mainland, Britsh Columbia
Fired up my Escape from the robot monsters today and the sound is missing, it was working fine lastnight. Tried adjusting the pot for the speakers and you can hear that the speaker volume is being adjusted but nothing happening and in self test mode it says the music chip tested good. Is the probably and amp problem?
Checked it out again in test mode and you can faintly hear the sounds when the volume is turned up all the way, Iam assuming the sound amp ic is shot?
