Error 25 Sega Naomi Initial D V3
8bitnintendo
Rocklin, California
I finally got my second Initial D to fire up, now it is saying that it is Error 25... Can not access GD Rom drive... how can I fix this???
We have a Naomi here, but it's a straight-up ROM game, no GD drive... I'd check the cable connecting the main computer and the GD-ROM drive for any damage or wear, and reseat the connection on both ends. If that doesn't work... you have two of these, and one works, right? Swap the entire drive with the known working machine, keeping the discs with their respective machines. If that doesn't work, try swapping the cables.
If you're still at no dice, you probably have a problem at the computer side, either with the connector, or possibly board damage or a BIOS ROM error. Carefully inspect the connector on the computer for any signs of damage, soiled or burnt conductors, poor mating, the like. If you've gotten this far with no solution, verifying the BIOS ROM is worth a shot.
"Can not access GD-ROM drive" sounds like it can't initialize the drive in the first place, so it's probably not the disc itself... but I don't really know. If you swap the drives and get a different error, try swapping the discs.
I have swapped everything and narrowed it to the GD Rom drives... I keep getting error 24 and 25... GDROM drive not found and GDROM drive not connected... how can I fix this???
There ya go!
Gotta love those cheap Dreamcast units. Every NAOMI owner should keep one around as spare parts. :)
