1-3-4 indicates a bad RAM 34. to verify that the RAM is actually bad, you can swap it with RAM 24. if the error changes to 1-2-4, then the RAM is bad and needs to be replaced. If it stays at 1-3-4, then the problem is most likely elsewhere (like with the power supply or the power connections to the CPU board), or maybe the chip socket for RAM 34. Sometimes the chip just needs to have the legs cleaned or be reseated fully.
I understand these are not exactly the number you are getting, and you will get some feedback that may or may not be relevant, but this will give you a good tour of Williams RAM problems.
