Eprom programmer question(s)
OMG KON
Bolingbrook, Illinois
So I have a beatmania machine at my house and it uses DJ main (which is very similar to KONAMI GX) and uses eprom's and an HDD for each game. Now one of my mixes currently is not able to boot due to one of the eproms not working, so I figured I would go and buy a eprom programmer and program a new eprom for my board.
I am pretty new to this process so I just have a few questions.
The eprom each mix uses is the same. The eprom is a M27C4001-10F1...
http://www.alldatasheet.com/datasheet-pdf/pdf/170525/STMICROELECTRONICS/M27C4001-10F1.html
I figured any eprom with the same pins and size (4MB) will work when I program a new eprom, is that correct?
I also wasn't able to find a 32 pin programmer, but a found a 40 pin programmer on many sites for pretty cheap...
http://www.plaza7.com/en-usd/g540-usb-universal-programmer-eprom-flash-gal-avr-pic-p29288.html
Can I still burn 32 pin eproms using this programmer?
Thanks in advance!
Well thanks for the help! That one is a bit out of my price range, but it did possibly answer one of my questions (if I can use a 40 pin programmer for a 32 pin eprom).
