MundoMan4
Hi All
I picked up a Sega Enduro Racer and everything but the steering seems to work.
When I checked I found the POT was removed. I bought another "working" controlpanel and found it too had the POT removed (3 wires were cut on both CP's Red-Blue-Black)
I do have a Control Panel for a Sega Hang-ON. From my reading it seems the EnduroRacer was the same system as HangOn except for adding a switch to pull up.
Would the POT for steering on the HangOn work for steering on an EnduroRacer????
The HangOn POT also has 3 wires(like EnduroRacer) but the colors are Red-Blue-Brown
I know how a switch works by just making an on/off connection, but not sure about a POT since it has to have different values as it turns.
Basically I need to know if I can use the POT from the HangON on the EnduroRacer, and if the pot would connect the same (except Black=Brown)
Here are pictures (not the best)
Sega Enduro Racer cut wires Red-Blue-Black
Sega Hang On POT with Red-Blue-Bnown
