Enduro Racer Steering and Brake
GrimJack0
Pennsylvania
I have an Enduro Racer that has a steering and braking problem. The switch test reports them working but the deflections are way off. There is a 5K POT that controls the amount of steering. I have measured the POT and it has a 1 - 5K deflection. The switch test reports a deflection from 0H to 3FH. The book says it should go all the way to 84H. In fact the deflection should be between 7CH and 84H with 80H as the center. The brake suffers from the same type of problem. I added another 5K in the like and it still goes to 3FH so that is the maximum value. The result is that the bike is always turning right and there is almost no braking.
Does anyone have any experience with Enduro Racer?
